rename filename
Hi all,
I have numerous files with filenames as follows:
1989 Feb 3 Name.mp3
2000 Oct 12 Name.mp3
How can I do batch conversion of the filenames to the following format:
1989-02-03 Name.mp3
2000-10-12 Name.mp3
In other words to change months and days with two digit number.
regards,
Pavlos
Some help guys?
You can start with "Convert > Tag - filename"
String:
$replace(%_filename%, Feb ,-02-, Oct ,-10-)
You must add the other months by yourself.
Is that all? So easy?!!
Thanks a lot Dano!
