i tried this and it was semi-successful
There are 2 more or less automatic ways to get a new files and folder structure with the help of MP3tag:
If you already have the right amount of folders - only the have not yet got the correct name, then try something like this:
Load the files, select them (you can load files from several albums at once).
Create an action of the type "Format value" for _DIRECTORY
Format string: %artist% - %album% - %year%
and "Bad" should become "Michael Jackson - Bad - 1991" provided, the fields are fille…
it did rename the subfolders, but the date format was not what i was looking for
they ended up as
Artist - Album (YYYY-MM-DD)
where the MM-DD was 01-01
not
Artist - Album (YYYY)
how do i control output format to YYYY for this purpose?
Please show us the mask that you used and tell us which action you applied.
To remove anything non-numeric from a string, try $num().
my problem is a lot of files were auto-downloaded with 'date' tag enabled, and the year fields show YYYY-MM-DD
is there a batch action to convert date from YYYY-MM-DD to YYYY? otherwise i am sorting them by year and manually editing each year by batch
Have you tried the $num() function?
Which field contains the long date?
year field
also using the
%artist% - %album% (%year%)
i want to rename the folder and leave everything intact
so it goes from
Artist - Album
-music fles
to
Artist - Album
-Artist - Album (year)
--music files
when i want
-music files
Try
%artist% - %album% ($num(%year%,1))
its cool i want to manually fix the year tags first anyway. just need to keep the files together instead of making new subfolders fo rthe music files
separate issue
where i have disc subfolders i have
Album - Artist
-Disc 1
-Disc 2
I want
Album - Artist (Year)
-Disc 1
-Disc 2
but its merging the disc 1 and disc 2 by tags, resulting in
Album - Artist
-Album - Artist (Year)
how do i only rename the top folder and leave disc folders intact?
You can only rename the current folder.
If this is the folder with the disc in the name, then this one will be renamed.
You could try an absolute path with
d:\mymusic\ ...
It could be, though, that the original folder without the YEAR is left over.
