Yes thank you. I got it.
In fact, the problem I have is that if before the title I have a number, it won't put the Upper case.
exemple :
Original title : 2 - Bounty Hunter
What I want is : 2 - Bounty hunter
But when I apply "sentence" to "title" with "Words begin from" : "- ", I have : 2 - bounty hunter
Thank you very much for your answer.
I couldn't find it alone....
Actually I found an other way to do what I wanted. Putting many actions.
Thank you anyway. It will be usefull.
