Hi Florian, hi team,
Thanks for a great tool that I've been using regularly for the past ten years.
There's only one issue I have with mp3tag and it has been there from the start:
Each time I want to normalize case in filenames and tags, which is my essential motivation for using mp3tag, I apply actions to tags, then click on tag->filename and your great software wrongly tells me that this file (or files) already exists.
It doesn't exist with the same filename, obviously, as I've just modified it. But since the OS (I use mp3tag on both WinXP and openSuSE) tells mp3tag that "ABC.MP3" is the same as "Abc.mp3", mp3tag repeats the same nonsense in a message popup, instead of performing a double-renaming action automatically by renaming "ABC.MP3" into something like "TEMP1234.MP3" and then the latter into "Abc.mp3".
There are two cases in which the OS can tell mp3tag that a file already exists under a given name:
1/ it's the same file (same inode) and the above double-renaming may be used safely, as the user obviously wants to rename that file by merely changing case.
2/ it's not the same file and would become an actual duplicate directory entry, possibly with a different case, but the OS doesn't allow that anyway and the user needs to be informed via a popup, as mp3tag correctly does when such cases arise.
That's so simple that I actually do it myself, manually, renaming files from "artist - title" to "title - artist" and then back to "artist - title". I've been going through this manual double renaming process for ten years now and would like you to tell me one of two things, pretty please:
1/ is there already a way to automate this process and would you be kind enough to share your secret?
2/ if nobody has thought of that before, would you please put it on your to-do list for the next release?
Many-plenty-lots of thanks in advance.
