Renaming Tool
Does anyone know of a great renaming tool.
here's what i'm trying to do.
Each folder I have has a the following items to support thr album
Ex: Natalie Cole - Inseparable (Folder) under the folder:
                      Credits.txt
What I want to do is find a program that labels everything by the folder name, to look like so:
Natalie Cole - Inseparable - Credits.txt
Thanks
You can do that with Mp3Tag.
Go to File > Options >tags and add *.txt and *.jpg with the semicolon-delimiter to "restrict incoming files to".
Load all album-folders to Mp3Tag.
Then filter for your TXT- JPG-files.
Use the Coverter - TAG-Filename.
Format String: %_directory% - %_filename%
Everything works - but I need , if possible to go one step further. It will label images as requested above as long as it is not in it's own folder.
see attached jpg. I need a way to change the Artwork Folder Name to successfully change the images witihn the folder.
this:
Credits.txt
Now Becomes This:
Album Art - Credits.txt
Is there a way MP3Tag can name the folder associated with the Artist. and also the images within the folder. (The attachment may explain better.
As I mention, the solution you gave me works, but I have to manually move all the files from under the Art folder and then iI get the results:
The solution I told you works because MP3Tag knows of the tags (Metag-data embedded in files) but also knows lets call it pseudo-tags (information tags), which are not embedded in the files itself.
So you can't use the artist-tag or the album-tag because in your jpg- and txt-files there is no such tag embedded and Mp3Tag could not handle them anyway, because they are no music-files.
So in my suggestion I used these pseudo-tags:
%_directory% (the directory in which the file resides)
%_filename% (the present name of the file without extension)
If your files you want to rename reside in a subdirectoty of the directory thats carries information of artist and/or album in its name, you can use %_parent_directory% instead of %_directory% to rename your files.
So you just would have to use:
%_parent_directory% - %_filename%
But I wonder why you say my original-solution works, because obviously the year is in the name of the directory too.
Do you want the year to be in the name of the txt- and -jpg-files too?
Otherwise you have to change the format string to:
$cutright(%_parent_directory%,7) -%_filename%
$cutright(%_parent_directory%,7) in this case cuts 7 characters from the name of the parent-directory starting from the end of the name.
This naturally only works like this in the case that there is always a year in the name.
Perfect
Thanks
I'm running into a problem where it states the file name is too long.
Is there a way to automatically cut off tag name until it matches the folder length?
This works for Parent Directory
$cutright(%_parent_directory%,7) -%_filename%.... I can manually change the legth 7 to 12, 15 etc.
Can it work for this action
Again, when saving files it says... file name is too long. Currently I just shorten the album manually... but that not a good solution when doing several folders.
Thanks
It is not the filename that is too long, it is the whole path including the filename.
https://msdn.microsoft.com/en-us/library/wi...5).aspx#maxpath
