I'm not sure if its possible to change this
size . %_total_size%
duration : %_total_time%
to
size. 162,56 mb
duration : 25:31 min
thanks.
You find these fields in the section of information fields. They are read-only.
To modify the size you would have to resample the file with a different sampling rate.
To modify the duration you would have to cut something from the file (which then would modify the size, too).
Thanks for your reply, sounds to complex for me... will stuck with the original.
DD.20131216.1841.CET
Worked like charm, thanks a lot.
