I have files with the outdated front covers, and multiple other embedded images. So my sequence is usually front cover, back cover, media, leaflet (for stuff I do have).
So an example is I have a file, front cover, media x5 for six total art. The position indicator of front is 1/6.
So now, I have a correct front cover that I want to insert into the first position.
I find that there is no way to move the "order" the files are dragged into the mp3 window.
Is there a way to handle this beside trying to export them all and then manually one at at time reordering them? I also need to convert the "old" front cover" to "media" as well.
I'm trying to semi automate it if possible as I have a bunch to modify.
Any thoughts?
TY.
Chris
