I am trying to reorganize my music onto a network HD now that includes reorganizing and redoing some tags / folders. Here is my issue, I am able to use MP3Tag to do the majority of this such as move the directories but when I go to create multi disc folders by renaming the files it puts them right back into the original folder that they were in prior to the move?
Presently what I do after I have the tags the way I want them:
Format Value "Directory" - $validate($replace(G:\Music$upper('['$left(%albumartist%,1)']')\%albumartist%\%album% $num(%year%,4), , ), %mediatype%,'_')
Now when I apply:
Format Value "Filename" - Disc $num(%discnumber%,2)\%_filename_ext%
It moves it right back to the original directory that I just moved it out of but in multi disc sub directories that I was seeking for the new folder...
I can get around this if I pull the files from the new folder back into MP3Tag than run the Filename format...but this seems to be an extra step that could be unnecessary.
Ideally I would like to be able to combine both of these together so that I could do the following:
Move to new folder and if Disc number is more than 0 (as I do not number single discs as this would seem to be another unnecessary step) than follow it up with the Filename formatting...
Suggestions?
