Hi Everyone.
I'm Using Mp3tag for the first time, and the only task i really want to perform with the software seems impossible and i'm already frustrated here.
I have read all the FAQs, Supports, help etc, but no one seems to be thinking in my direction.
All I want is to give a single field a particular name for all the tracks in the list...
this seems to be easy if that field already had a content previously, i could use Action-replace to change from the old name to the new name. BUT my problem is to give a name to the field that is Blank.
For example.
I have a list containing songs from the same (local) artist or album. and the album or artist name was not previously given (which means it was blank) now i want to give the entire list, the same artist name (although this can be done manually, one at a time, but suppose my list is long)
I tried
to use Action-Replace, then in the Original, I left it blank, and in the Replace with box, i typed the name i wanted... but it refused to work.
Please friends, i'm really frustrated here, I've wasted so much time tryin to figure this out, but i think the developers didnt think it's one of the most important features to consider giving a menu or icon.
Your help will be greatly appreciated
thanks in advance
It worked!!!.
