Is it possible to detect and replace symbols and spaces with the standard replace option?
I'm looking to emulate the find and replace option I used previously.
As examples, replacing double brackets, Inst with Instrumental, Acap with Acappella.
Another example is , to be replaced with feat.
I was trying to use the standard replace action but it's not working.
