Replace Artist with ArtistS
Hi simple request but after many forum searches and attempts myself i cant figure it out sorry.
I would like to make an action to replace the contents of ARTIST with ARTISTS then blank ARTISTS.
I tried format value but in many cases my ARTISTS tags have more than one value and it just takes the first value. Id like to preserve the multi-value aspect of the tag once put into ARTIST.
Thankyou in advance
Create an action of the type "Format value" or use Convert>Tag-Tag for ARTIST
Format String: $meta_sep(artists,\\)
Then delete the field ARTISTS
Ok that worked thankyou.
I used Format Value, Format Field: Artist, Format String: $meta_sep(artists,\\)
Then added a s second task to the action, Remove Field: Artists
Seemed to work well. I do have to be careful though not to run the action on any songs ive already processed otherwise itll overwrite the Artist field with a blank!
Thanks again
You could filter for files that have the ARTISTS field with
artists PRESENT
Thats a good idea as i intend to run this on my whole collection in one hit :+1:
