"Wolfang Mozart\\Artist Name, Artist Name, Artist Name"
How do I replace the commas with \\
Can someone explain what the difference between Convert Tag - Tag and an action is?
I've seen posts that are close to this that seem to suggest both.
Thanks,
Simon
"Convert" is an interactive way to achieve the same result as with the automated Action.
Using the Convert Tag -> Tag interactively is more for non-repetitive steps, where you like to see the result before you execute it.
Actions are for steps that you repeat again and again.
