1st request - trying to REPLACE (feat. ) with (ft-)
2nd request - trying to REPLACE (/) with ( & )
I cannot figure out the correct expressions. Can someone kindly help me please?
Blessings, John
Blessings, John
What have you already tried?
This is pretty straight forward. Using the Actions (Quick) -> Replace function
Field: (I am assuming TITLE or ARTIST from the above info)
Original: (feat. )
Replace with: (ft-)
You can run the Replace action again with your second request "REPLACE (/) with ( & )" and also change the field as required.
Thank You, Thank You, Thank You.
I learned something new today!!!!
Blessings, John
