Hi everyone
I use the $replace format string regularly to alter characters of choice when renaming files or setting up actions. For example, thsi is one where I change the regular brackets into curly brackets:
$replace(%discnumber%-%track%. %title%,(,{,),},)
I have also tried variations of the foregoing string, such as:
$replace(%discnumber%-%track%. %title%,(,{,),})
Since version 2.77, the format string does not achieve the desired results at all, and I hope someone can pinpoint my mistake. I would also like to know if the following format string may be used to achieve the same reult as my original above:
$replace(%discnumber%-%track%. %title%,(,,),{,,},) (based on this one)
or
$replace(%discnumber%-%track%. %title%,(,,),{,,})
Thanks.
