I want to make a tag command that detects a hyphen in the filename and replaces it with a colon in the title field and vise-versa. Example:
The Matrix - Reloaded (2003).avi > The Matrix: Reloaded (2003)
The Matrix: Reloaded (2003) > The Matrix - Reloaded (2003).avi
I understand if I need to make two seperate commands, I just want both to make organizing faster;
poster
2
Define 2 actions:
Action 1:
Type: Format Value
Field: TITLE
Format string: $replace(%_filename%, -,: )
Action 2:
Type: Format Value
Field: _FILENAME
Format string: $replace(title%,:, -)
Edit because of typo in the format string:
Format string: $replace(%title%,:, -)
Thank you for the reply, the first action works but the second one always returns a syntax error.
poster
4
Yes, there was a typo in the format string:
