I have a set of actions for fixing (changing all letters to uppercase) roman numerals in track names and they use the Replace action and select "only as whole word" option.
The seem to work correctly except in the case where the roman number is immediately followed with a period character, in that case the string is not replaced.
Example Actions: (all with 'only as whole word' ticked)
Replace "ii" -> "II"
Replace "iii" -> "III"
Replace "iv" -> "IV"
I can confirm that the action "Replace" behaves in the way that you described.
Fascinatingly, the function $replace() works on a string like this: $replace('A New Found Glory Ii A New Found Glory Ii.',Ii,II) - > A New Found Glory II A New Found Glory II.
Edit: I would like to add that any punctuation following the search term will hinder the function to replace it.
I tested it with !?;:,
I think that there is the DIN 5008 that constitutes typographic rules where to put a space character and what to do with punctuation (Satzzeichen ";:,.!?) plus non-aphabetical characters (Schriftzeichen §$%&/=\#'+*-<>|^°(){}[])
So I would appreciate it if some more characters could be added to define words.
As ohrenkino said, it would be great if in addition to spaces, it could also treat punctuation characters and non-alphabetical characters as word separators.
Who knows? There are so many countries and so many alphabets.
I doubt that the DIN has any relevance in other countries than Germany. And there is not only the german and english language. And there are a lot of alphabets.
Could you supply examples where the classical punctuation characters appear in the middle of a word?
Otherwise I would still assume that punctuation comes on top of the classical space character and is helpful in those languages that use punctuation.
They more or less prove the point: Abbreviations should be capitalized and not become U.s.a as they do now and in repect to numbers: I don't know what a small or capitalized number would look like - they simply stay the same.
So the question remains: is there a language where a punctuation character appears in the middle of a word?
An alternative for the "Replace only as Word" function would be to add the option to add user-defined characters like in the case conversion action. This list should be remembered and become only active if the option "as word" has been selected.
Apostrophes may occur inside words in a number of languages, as can hyphens. In others, they may be separators instead. Considering gender-inclusive and other creative language practice (as is common in band names and song titles at least in some genres), exclamation marks, colons, middle dots, currency symbols, digits etc. can also be part of words. Furthermore, some of these characters are often replaced by similar ones, e.g. ', ʼ, ` and more for apostrophes.
In conclusion, provide a useful default, but make it customizable.
Apostrophes are no punctuation characters and neither are currency symbols, digits, accents.
In my understanding punctuation includes only the classical characters ,.;:!?
But making it customizable is probably the silver bullet.
As usual, it is not as simple as it may seem at first, especially if you start to consider non-European scripts. Even without looking at particular languages (which CLDR does), Unicode has dedicated categories for
Thanks all for your input on this. I've chosen a fairly pragmatic approach and extended the list of characters that mark word boundaries with Mp3tag v3.00e.
Currently, I prefer to have the few edge cases that have been pointed out here and handle them individually over a much more larger group of standard users that would have to deal with yet another configuration option (even if it would provide a sensible default).
Let's see. The report from the OP should be addressed by the new version.
I'm sorry, but I think it's unfortunate not having user control over this. I have too many Replace actions in my often very large Action groups to feel safe about the change. IMHO the previous default should not be changed - so either don't change anything or make it optional.
For me it's better to be safe than sorry, so I'll have to stick with v3.00d.
FWIW, the OP could simply use multiple Replace actions to solve the problem.
