Hello,
is there a way to replace the title like this with regex?
my regex is pretty rusty lol
01.title (Prod by XXX)
to
01.title [Prod. by XXX]
Hello,
to
If you want to replace Prodwith Prod. then it is a simple replace.
There is an action for that.
The same applies if you want to replace opening and closing brackets with their square equivalents.
Sorry that I expressed myself unclearly.
I have files in the following format:
02.title (feat YYY)
03.title (feat ZZZ) [Prod. by XXX]
it just has to be recognized whether Prod by is in the string and only then the brackets are replaced
thx for your help
this should come out in the end:
02.title (feat YYY)
03.title (feat ZZZ) (Prod by XXX
you could try:
$regexp('03.title (feat ZZZ) (Prod by XXX)','(.*)\(Prod(.*)\)',$1'['Prod.$2']')
Which leads to
sorry for the stupid question
what goes where?
Regular expression:
Replace with:
Scripting functions can be used in format strings.
So an action of the type "Format value" would be good. Or the Converter>Tag-Tag.
You have not yet mentioned which field you want to modify.
I got it thanks to your answer
Field: TITLE
Regular expression: (.*)\(Prod(.*)\)
Replace with: $1[Prod.$2]
