Is there substring function in mp3tag?
How can i replace string "123ABC456" with "ABC".
Thanks for your help and kind regards.
Look for scripting functions there ...
https://docs.mp3tag.de/scripting
If you want to remove digits from both sides of the given string, ...
then you may apply the function ...
$trim('123ABC456','0123456789') ==> 'ABC'
DD.20151107.0659.CET
