Some of my genre fields have \\ in them ie blues\\rock
I want to change the \\ with an action but I assume the software thinks the first \ has special meaning. I can't make it work anyway.
Is there a way of writting \\ so that mp3tag knows it is a double backward slash that needs replacing.
I have hunted the forums but can't spot anything that I can make work yet.
Thanks
Oh I had been on that one but didn't make much sense of it. I think I have spotted the issue is that \\ isn't in the field itself. It is a field that is in the data twice. I will just have to carry on editing it manually. No problem
PS I didn't think to write double backslash until I saw the formatting here didn't work either. I can now look for other threads too.
Thanks for the pointer
You can merge two (GENRE) fields into one as mentioned in the linked thread with
Yes thanks. I have just tried that and it does indeed sort it. Thanks for your help.
