Hi All, Hope one of you wizards can point out what I'm doing wrong please. I've been using MP3Tag for a while but cannot fathom out why I'm stuck on this issue.
I'm trying to replace the contents between square brackets and not making any progress.
Here's an example that works exactly as I expect:-
This one replaces four numerals and text inside parenthesis with just new text also inside parenthesis;
Regular Expression ((.... Some Text)) Replace Matches With (New Text)
I want the same outcome where there are square brackets instead of parenthesis eg:
Regular Expression ([.... Some Text]) Replace Matches with [New Text]
I've tried putting apostrophes around the brackets as follows; ('['.... Some Text']') and also ('[.... Some Text]') but neither works and leaves the original string unchanged.
Incidentally, If I use the replace command for "TITLE": "[TEXT]" -> "" then it successfully deletes the brackets and the content.
Am I missing something obvious?
Thank you...
Real expression is [1982 Remaster] and I want [Rem]
As previous if (1982 Remaster) accurately becomes (Rem) why doesn't it apply the same logic to the square brackets phrase but leaves it intact instead?
Will try [1982 Remaster] as you suggest.
Brilliant, thank you. Spent ages on this and you seem to have done it in 5 minutes. also your round brackets suggestion is much neater too.
Many thanks.
