I'd like to replace all blank disc numbers with a one, but am unable to figure out how to match a blank...
In vi i'd just use
^$ but this doesn't seem to work. How can I pattern match a blank field?
Thanks
In vi i'd just use
Thanks
You can use a different action type:
Action type: Format value
Field: DISCNUMBER
Format string: $if2(%discnumber%,1)
which means if %discnumber% has already a value, keep it. If not set it to 1.
Thank you.
