gsa999
January 14, 2016, 6:36pm
1
Using a Format Value Action I am trying to replace the genre in the embedded cuesheet with the actual genre (which has changed since first rip)
Trying this, but its not working
$regexp(%cuesheet%,’^(.*?REM GENRE )(.+?)$’,‘$1”%GENRE%”’)
The double quotes round %genre% are to handle genres with a space in them
Any ideas what I am doing wrong.
Thanks
G
Double quotes: use " not ”
Single quotes: use ' not ’
gsa999
January 15, 2016, 5:54am
3
Thanks. That is a lot better now but it is not picking up the genre correctly instead its replacing the old genre with the text %GENRE%.
G
I would say that the last part should be
,$1%GENRE%)
without any quotes
gsa999
January 15, 2016, 11:19am
6
DetlevD:
CUESHEET <== $regexp ( %cuesheet% , ' ^(.*REM GENRE )(.+?)([\r\n]+.*)$ ' , ' $1 ' %GENRE% ' $3 ' )
... or ...
CUESHEET <== $regexp ( %cuesheet% , ' (.*REM GENRE ).+?($.*) ' , ' $1 ' %GENRE% ' $2 ' )
DD.20160115.1215.CET
Excellent, thanks this works (I used the second shorter version) perfectly.
I now want to add an If condition to check whether the GENRE has a space in it or not. If it does it needs to be inserted in quotes in the cuesheet; if no space it does not need quotes. I tried this but it just shows the code in the cuesheet
$regexp(%cuesheet%,'(.*REM GENRE ).+?($.*)','$1($if($eql($strstr(%GENRE%,\s)),0,'%GENRE%',"'%GENRE%'"))$2')
DetlevD
January 15, 2016, 12:50pm
7
I have tested my regexp proposal with a tagfield set to GENRE <== 'Pop Rock' ...
that means within the tagfield GENRE there are no quote characters, ...
and the regexp works.
But within the cuesheet itself ...
https://de.wikipedia.org/wiki/Cuesheet
https://en.wikipedia.org/wiki/Cue_sheet_(computing)
... there are double quotes used in the REM lines, ...
when there is ... t e x t ... which contains space characters ... or not.
Therefore, for sure, write always double quotes around the text.
CUESHEET <== $regexp ( %cuesheet% , ' ^(.*REM GENRE )(.+?)([\r\n]+.*)$ ' , ' $1" ' %GENRE% ' "$3 ' )
... or ...
CUESHEET <== $regexp ( %cuesheet% , ' (.*REM GENRE ).+?($.*) ' , ' $1" ' %GENRE% ' "$2 ' )
Maybe you have to repair doubled double-quotes ...
CUESHEET <== $replace ( %cuesheet% , ' "" ' , ' " ' )
DD.20160115.1500.CET
gsa999:
... $regexp(%cuesheet%,'(.REM GENRE ).+?($. )','$1($if($eql($strstr(%GENRE%,\s)),0,'%GENRE%',"'%GENRE%'"))$2')
The quoted formatstring has no correct syntax.
It should be written as ...
$regexp ( %cuesheet% , ' (.*REM GENRE ).+?($.*) ' , ' $1 ' $ifgreater ( $strstr ( %GENRE% , ' ' ) , 0 , ' " ' %GENRE% ' " ' , %GENRE% ) ' $2 ' )
... or ...
$regexp ( %cuesheet% , ' (.*REM GENRE ).+?($.*) ' , ' $1 ' $ifgreater ( $strchr ( %GENRE% , ' ' ) , 0 , ' " ' %GENRE% ' " ' , %GENRE% ) ' $2 ' )
DD.20160115.1803.CET
gsa999
January 16, 2016, 7:12pm
9
Thanks so much, I messed around for ages trying to get the $if statement to work. This works perfectly. I used the second version.
Thanks
G
