Request: context menu item when selecting more than 15 folders
I'm using Windows Vista (32bit) and have my music sorted in folder like this:
artist a\album 1
artist b\album 1
Most of the time i use windows explorer and select one or more artists to perform some edits. When you select more than 15 folders in Windows Vista at once, the context menu is missing to launch MP3Tag.
I believe Windows Vista checks the number of folders and changes the context menu to not display certain actions you can do.
It would be a great addition if the context menu item would always appear regards of the number of selected folders.
WinRAR for example does have a context menu item when i select more than 15 folders.
Thanks for listening and keep up the good work. It's a great utility!
Best Regards,
Birkoff
