REQUEST: Encode Playlist as Unicode/UTF-8
Hi!
(note: I haven't found any related topic through search or the FAQ section)
I own the SONY Network Walkman NW-A25 and it does not support playlists created by mp3tag since they are encoded as ANSI.
After playlist creation I have to manually open the playlist (as text file) with Notepad++ and convert the encoding format to UTF-8-BOM. Only then the playlist is recognized by my player.
What about an option for the encoding format of saved playlists?
see the options for exports:
https://docs.mp3tag.de/export
if you create a report that results in a playlist, you can set the encoding.
Yeah, but that requires some coding skills ... and having this option built right away into mp3tag would make life much easier.
I'll take a look at the export function though.
you could have a look at: /t/13912/1
Go to Options > Playlist and change the extension of the playlist filename to m3u8
