Request: Filter history enhancements
  1. Would like to be able to pin/unpin commonly used expressions in the history list.
  2. Have an option to clear all filter history items instead of one at a time, while leaving pinned items alone.
Thanks for your consideration.
Bump.
Is 5 years too soon? :smiley:
Don't know.
Perhaps you have a look at this thread that describes a local solution to keep a sort of history plus explanation:
/t/12361/1
Not quite the same as pinning but perhaps with a similar result.
Thanks ohrenkino! I do that already though.
I could also suggest saving the filter history in a user editable format.
e.g. filters.ini file
So we can change the contents and order of items.
Please Florian!!
