I would like to start some kind of brainstorming how the handling of embedded images could be enhanced.
Definitely on my wish list would be functions
to set image types via actions,
switch one type of image to another with an action,
remove only specific images of a certain type with an action,
treat images like multi-value fields so that one could see e.g. all the types of embedded images with a function like $meta_sep(_cover_type,\) in a files list column
get away from the order "1st, 2nd, 3rd" to an addressing system that uses the type of an image.
set the image description for more than just one file at a time (and also remove the description) as well as action as a function in the tag panel.
Right now some of the functions are there but only for a single file at a time, the only way to determine the image type with an action is during import so that a lot of manipulations rely on the detour via the file system - it should be much easier to do the manipulation of image tag attributes within MP3tag.
In addition to your list I would like to see some kind of image resolution manipulation possibilities.
It should be possbile to set an embedded cover to a defined resolution without additional 3rd party tools.
At least a "shrink this embedded cover to this resolution"-command would be great.
If "shrink" then why not "scale up"? Or simply just: "resize" [with at least an option of a fixed ratio of 1:1]
Somebody might want to make them bigger, because how a given player shows them. Even if that would mean "pixelizing" them [but small increases like to 120% of original are pretty much of the same quality / readability]
And with that would nicely go along implementation of these features:
I would like to emphasize that the functions that I had in mind only deal with the container of the embedded image - and not with the image itself.
My request is not the attempt to make MP3tag into a graphics program.
