I'm new here, so I would like to say hello first ;-).
I would like to make a request for a conversion function that converts all national characters to Latin counterparts (if possible), leaving Latin and unknown characters intact. The first version might handle just European characters (I believe I read somewhere that this could be done with some Win32 API, but I am not sure), in the next versions the list of recognised characters could become longer.
I understand that this could be achieved with series of replacements right now, but this is not very comfortable, especially if you would like to define transformation for all European languages.
Rationale:
I would like to use this function in the "Convert -> Tag - Filename" context.
Although we normally use national characters in tags, the file names are much easier to handle without them, because especially when transferred between various servers and operating systems, the national characters often get lost or converted to something unreadable. And the media players often have very basic, lightweight OSes.
Please consider adding this function. Should be easy to implement, and I find it extremely usable.
Did you have a look at the
$validate()
function? It helps to create legal filenames.
Also, there is the $replace() function that allows you to create longish lists of pairs of characters that should replace each other.
This function could help you get those translations. Yet, you have to do it according to your requirements.
Both functions can be used in conjunction with the Convert-function in the menu as well as the format value actions.
Thanks for your answer.
Yes, I know about the two functions and I am aware that this is a workaround, yet creating a replace expression that is good for - say - all European languages would be quite a nasty job.
My request is motivated by the fact that this new function should be quite easy to implement and maintain for the developers, and a very useful "out-of-the-box" tool for the users.
That's only my suggestion anyway, let the Mp3tag developer(s) decide.
After a brief look at this library, I'm not sure if this is really useful when they say:
A user expects a character to be transliterated in their language but Unidecode uses a transliteration for a different language. It’s best to not use Unidecode for strings that are directly visible to users of your application.
As an example from their FAQ:
German umlauts are transliterated incorrectly
Latin letters “a”, “o” and “u” with diaeresis are transliterated by Unidecode as “a”, “o”, “u”, not according to German rules “ae”, “oe”, “ue”. This is intentional and will not be changed. Rationale is that these letters are used in languages other than German (for example, Finnish and Turkish). German text transliterated without the extra “e” is much more readable than other languages transliterated using German rules
I doubt that many German users would agree with the last sentence.
German words with umlauts like
Städte -> Staedte -> Stadte
Dörfer -> Doerfer -> Dorfer
Kühe -> Kuehe -> Kuhe
reduced to the base character are indeed less readable - at least for German readers.
Thanks for your feedback. Having in mind all the drawbacks, I still think availability of 'unidecode' might be useful. Please note that it would be used to change file names, not the tags. Filenames in a plain ASCII are just safe across various operating and file systems, and decently readable in most of them. And a 'decent readability' is enough for a file name in my opinion.
As for me... I would use this function if it were available.
I'm just curious:
What kind of "conversion" would this tool do with Unicode characters like in this album if the filename for the titles would be converted?
Maybe I just don't understand the purpose of the library?
Should it convert any NON-ASCII-character to an ASCII-Character?
Or is the library name "Unidecode" just misleading for me?
CMD-Window with Font "Consolas":
If I redirect the output of DIR in a test.txt file, the content of test.txt looks like
Luckily, I found this album in my collection. Unidecode will not help in this case:
PS E:\Doc\MMedia\Music\Coldplay\2021 - Music Of The Spheres> ls -n
01 ⦵.flac
02 Higher Power.flac
03 Humankind.flac
04 -✧.flac
05 Let Somebody Go.flac
06 .flac
07 People of The Pride(Explicit).flac
08 Biutyful.flac
09 ❍.flac
10 My Universe.flac
11 ∞.flac
12 Coloratura.flac
PS E:\Doc\MMedia\Music\Coldplay\2021 - Music Of The Spheres> ls -n | unidecode
01 ?.flac
03 Humankind.flac
04 -?.flac
06 ?.flac
08 Biutyful.flac
09 ?.flac
10 My Universe.flac
11 ?.flac
12 Coloratura.flac
(note that the forum displays icons on the output of plain ls -n, but in the console they are not visible - I see rectangles instead)
I'm not sure and can only guess that the original intention of the author was to 'latinise' symbols that are alphabetic. Not all unicode symbols. So this result, although not satisfying, might be expected.
Anyway, if such a function is available in mp3tag, the user has a preview option before renaming files, so (s)he can decide to use it or not on a particular set of files. I believe that in most cases it would still be useful.
