Request: Multiline Comments in Tag Panel
I wish I could enter multiline comments through the Tag Panel rather than having to use the Extended Tags dialog. My personal habit is to tag all tracks on an album with the same comment, so I have no use for the drop-down behavior with or . And I use the Tag Panel almost exclusively for any album-wide field editing, with needed custom fields added below the default ones.
An option in File > Options... > Tag Panel to make the standard Comments field multiline would be very welcome.
