REQUEST: Replace cover art in place
Add option to replace a single cover art image in place (without changing displayed order) by selecting image file from directory.
I propose adding "Replace" to the list of options available from the right mouse button context menue for cover art:
Add cover...
Remove cover
Replace cover...
Extract cover...
Adjust cover
Example: I have images installed for Front Cover, Back Cover, Leaflet (multiple leaflet images). I want a file selection dialog to replace Front Cover without changing the order of images.
Alternatively: A dialog box for dragging images into any order.
I've just released Mp3tag v3.27e with the option to replace the currently displayed cover.
Great news, thanks! This adds appreciated flexibility to Mp3tag's already excellent image handling.
Now I believe the only thing missing is "Insert cover before..." the currently displayed image, which I'm sure you must be thinking about... :smile:
