When we click the icons on the menu, such as Tag-Filename or Filename-Tag the field where the action is highlighted. I would like the OK button to be highlighted. This would make things run much faster as I could click the icon and press the space bar and the action is done. As it is, I click the icon and then move the mouse to find the OK button. Normally, we use the same action like Tag-Filename with Artist - Title or however you name your files.
Just wanted to say I appreciate all the work that has gone into making and maintaining this program. I am getting older and get proficient with this program, then don't use it for a while and end up back at square one. So, I also appreciate the moderators and the others that help answer questions.
