Reset the option to replace cover when importing from sources
Hello,
I am using the source tag imports from discogs. On the first import i was asked if I wanted to replace existing covers by the source ones. At first I didn't want that behavior and answered "no" + checking the "never show again" option.
Today, I want to reset that behavior in order to replace the covers because I realized that the covers from the source tag were not replacing the existing one as expected but they were appended to the covers. I didn't realize it would do that at first. Now i have similar duplicated covers every time I import data where I already have the cover.
I couldn't find any option in the settings.
If anyone has the solution, I would really appreciate ! :slight_smile:
Are you looking for this checkbox under the cover art?
Or this message option:
