Hi:
When I run my custom actions for various tag operations (from the actions menu), if the formatted tag changes are more than zero, those counter values shown on the pop-up dialog will never change on subsequent custom actions unless I do a full refresh (F5). Re-reading tags does not reset that counter (CTRL-T).
Steps:
[Actions Menu] -> [Custom Artist/Title String Replacements Action #1]
After the action completes, the pop-up dialog reads:
"Formatted tags in 10 of 20 files. 0 of 20 files renamed"
Run the same custom action again.
Even though there are actually zero changes (as expected), the pop-up dialog still shows the same counter values from the previous run:
Do a full refresh (F5).
Run the same custom action again.Pop-up dialog now shows:
"Formatted tags in 0 of 20 files. 0 of 20 files renamed"
This may only apply to custom actions. Quick actions and others seem to reset their counters from what I've noticed.
This isn't a new issue but wasn't always an issue either. I'm not sure what version it started.
I'm currently running 3.02. Thanks.
