I'm trying to export a list of mp3 tags into a template I've built for an XML file. The problem is that I need to reverse the order of the loop so they appear in the proper order. I've searched the forums and found a $reverse function, but I admit, I don't know where it goes. So for example:
$filename(New_export_file.xml,utf-8)<?xml version="1.0" encoding="UTF-8"?>
<rss
xmlns:itunes="http://www.itunes.com/dtds/podcast-1.0.dtd"
xmlns:media="http://search.yahoo.com/mrss"
version="2.0">
<channel>
<title>Real FamilyLife with Dennis Rainey</title>
<description>Life may be hard... but the precepts of the LORD are right, giving joy to the heart (Psalm 19:8). Real FamilyLife with Dennis Rainey, provides godly wisdom for life's toughest questions.</description>
<link>http://www.familylife.com</link>
$loop(%_filename_ext%)
<item>
<title>%title%</title>
<description>%comment%</description>
<link>http://www.familylife.com/page.htm</link>
<enclosure url="http://d1ekldu2q29g.cloudfront.net/%_filename_ext%" length="%_file_size_bytes%" type="audio/mpeg"/>
<pubDate>%pubdate%</pubDate>
<itunes:duration>%_length%</itunes:duration>
<itunes:author>%artist%</itunes:author>
<itunes:explicit>no</itunes:explicit>
<itunes:block>no</itunes:block>
</item>
$loopend()
</channel>
</rss>
Where shall I put the $reverse function? And would it look like $reverse(%_filename%)? Thanks in advance for any help!
