Does it matter that the $rg2sc function puts a leading blank space at the start of the data it outputs?
Thanks.
Thanks.
Who knows? Only you can answer that question. It's like asking if it matters that the word "kill" starts with "k".
It's normal (all my iTunes bought Music Files contain that space also).
If you wanna know why it is, you have to ask on a Apple forum.
(Thanks for the input, ryerman.)
OK mike_nl... I guess it is fairly normal, then, even if yet another apple quirk.
