EDIT: False Alarm. Rebooted computer and mp3tag returned to context menu.
Just installed ver 3.25 (64 bit) on Windows 11 (Enterprise Edition, Ver 23H2, OS Build- 22631.3155). I can no longer right click on a folder of music files (FLAC) or an individual FLAC, mp3, or WAV file and see "mp3tag" in the context windows menu for opening the files in mp3tag.
I've been running prior versions of the 64 bit mp3tag program, including on the same machine running Win 11. All was fine before the update to 3.25. Any thoughts on how I can find whatever setting has changed. Thanks in advance for any ideas.
edit: it is not in the "show more" context menu either.
I added mp3tag.exe as a shortcut item in the context menu "send to". But seeing mp3tag directly in the context menu would be better of course. I see that others have had this issue, but most seem to simply be missing the "show more" option or returning to the Win10 style context menu. Even if using the "Shift/Right Click" approach to see the Win10 context menu, I still don't see mp3tag as an option.
I also installed an older version 3.22, but also now don't see mp3tag in context menu. I was using 3.24 until today, and mp3tag was showing in context menu. It is highly possible that installing 3.25 was the first time I've updated mp3tag since updating to WIN11 on my machine.
