right click option in explorer
#1
Hi I do not have the right click option in windows explorer for opening a file with mp3 tag I used to have it but it is gone i tried to reinstall no luck how can i get it back
Thank You
Ken Holderbein
kvholderbein@shaw.ca
#2
This option is disabled by default in the installer. Re-install and make sure you have the "Explorer Context Menu" option checked.
If that still doesn't work, check the file associations in FileTypesMan (http://www.nirsoft.net/utils/file_types_manager.html), if it shows up there then you have something else preventing them from showing in the context menu. If they aren't in FileTypesMan either, you can add them manually to the file types you want.
#3
what am i looking for to add it, it use to be there, now it doesn't matter how many times i install or uninstall it doesn't show up
Thanks
#4
It's on the third page, titled "Choose Components".
#5
Thank You Thank You it works like a charm
