Shift + F10 is supposed to work on win OS for most apps.
Has anyone had any success here?
yes
Cheers.
I'll just use my Jedi mind tricks now shall I?
Thx, I never knew about this shortcut.
When I select a song in the Mp3tag panel and press SHFT+F10 I get a shortcut menu, with for example "Play, Save Tag, Remove Tag" so the same shortcut menu when you Right Click on the Song.
Ps: I am using Win 8.1
It's not working here. Windows 10.
Do you have any file selected?
I wish I was that stupid ![]()
I'm not sure. Maybe another app has it hooked to that shortcut as a global but I never set one for SHIFT+F10.
Figured out how to get the tool popup using AutoHotKey.
THIS post will explain how to install it.
Here's the script.
; Short-cut: CTRL+T
; Quick RMB Tool Context menu
; If you want this to fire up a tool in mp3Tag, then rename
; the tool to have an ampersands in the name to represent the last button pressed.
; e.g. '&Youtube Search' (see {y} below)
#IfWinActive ahk_exe Mp3tag.exe
^t::
Sleep, 500
SendInput {control down}{shift down}{f10 down}
SendInput {control up}{shift up}{f10 up}
send, {t}
; Line below is optional. Here you can fire up the tool using the letter represented by the & in the tool name.
; send, {y}
Return
#IfWinActive
