I often make a change to a file or set of files & then proceed to run an action on said file(s) using a keyboard shortcut.
In these scenarios I usually click another random file or deselect the file(s) that I just saved / changed. The blinking typing cursor, if present means that a keyboard press of "ALT + A" will take me to a tag field (usually gets highlighted) & then any subsequent key clicks will overwrite said tag field instead of mp3tag running the action as it would if I had only selected a file & then immediately proceeded with my keyboard shortcut "ALT + A + C" for example.
The other workaround would be to trigger the action by clicking the action menu & selecting the action from there but this is often slower.
Is there any way to exit tag editing (remove my blinking cursor) without needing to deselect & subsequently reselect my target files?
I'm sure this is a simple oversight on my end but any help would be appreciated.
My end goal is simply to be able to change the year on 5 tracks for example, & then with those same files selected use a keyboard shortcut to trigger an action without needing to open the action menu manually or deselect & reselect my file(s).
