Running multiple instance
#1
Hello everyone!
I just wanna ask on how do I open multiple instances of Mp3tag i.e. open more than one Mp3Tag program/window concurrently? This is very useful when I want to do the ID3-Tag Copy from another folder to another.
That’s all. Thank you very much.
Mp3Tag really rockz!!! Thank so much you guys!
feature request: directory browser on the app
Feature request: Support for multiple instances
Opening more than one instance of program
#2
This is not possible as it would bring a lot of problems with handling the saving of settings and such. :slight_smile:
#3
:frowning:
What a great disappointment for me… :sunglasses:
This is because recently I am reproducing my mp3 from my CDs using a new software. And I want to update them with the same tags from my existing mp3 collections (the same CD collection).
As you can see, this task could be easily done if I can open two or more windows at the same time so that I can copy tag from one to another since they are residing in two different folders.
I would highly appreciated if you guys could make the program run multiple instances at the same time. Or at least could make something like tree navigation (Windows-Explorer style) so that one could easily browse from folder to folder without having to click the “Change Directory” button.
Thank you so much.
#4
Well, as stated already, it is difficult to implement because of the way settings are loaded and saved.
A folder tree is not planned as you can see from the road-map, but you can use the folder history to easily switch to one of the last used directories.
#5
AFAIK you can copy tags from one set of files and then point MP3Tag to another folder/set of files, highlight the corresponding files, right click and paste tags. I’ve done it many times on 10 - 20 files at a time and it has always worked. Not sure how it would go copying tags for hundreds or thousands of files, though I suspect it would not present any problems (subject to Windoze memory considerations).
