Hope someone can help me out.
When i right click a song and go to tools menu , i get a runtime error
file: y:\projects\mp3tag\mtmmainframe.cpp
line: 5251
i have a couple "tools" setup and they are all doing this.
Perhaps you rename the mp3tag.cfg and see if a fresh start with that leads to a more glitch free performance.
(Rename so that you can re-use it if that did not remedy the cause)
Another attempt would be: rename the tools.ini file and then (after a restart of MP3tag) create a new tool and see if it works. If that is the case, then the tools.ini is corrupt for whatever reason and you have to create the tools anew.
I tried the re-naming of mp3tag.cfg and tools.ini and had same error after making a tool again.
on a different computer i installed 2.88a and tools worked. I then installed 2.88h and am having same error
here are 2 of the tools from the tools.ini
I aslo tried directing thru to firefox and opera and neither worked.
I aslo tried just building a tool to open /windows/notepad.exe without any parameters and same error(worked on 2.88a)
(forget my last post tested from the wrong folder.)
Anyways, i retested , and the errors are only coming when the files are on my network drive.
I went back and tested the different betas.
2.88e test ok
2.88f runtime line 5260
2.88h + 289 runtime error 5251
is this a bug or is this a problem just on my network?
I am using an "Unraid" samba share
