Yes, thank you for your reply, I did it so (similar, I mean).
Oh! It is nice, I did this folder.
By the way -- thank you very much! It was I thought a suggestion (I mean, save panel's configs). Now I have already 4 of them: for pop and for classical, vertical and horizontal.
Not a "problem", a bug, only interesting: there is 1 record (file). Selected. In context menu I change the Tag Panel's config (from Pop vertical to Classical vertical). The record remains selected -- but the data in Tag Panel is invisible. I must to click on a blank space, then select it again, to see data in Panel. And, it is not enough to "once more" click on an already selected line -- first I must to click on a blank space.
