2.88b, win7x64hun
3 files in the table. In tags' panel there is TOTALTRACKS (and a column, too). (But works -- I mean, does not work
-- with any other tag, too.) 2 of 3 files have the value 21, the first file has 3. I select all files, in left tags' panel select "21" value, then click with mouse on a blank part of the table. The value "3" of the first file does not change to "21".
But!
If I select only the first file, in the left panel write "21", then click on blank part -- the new value "21" is saved.
If I select all 3 files, in the left panel overwrite < keep > with "21", then click on blank part -- the new value "21" is saved.
Clicking on "Save" button works allways. Tried with vertical an floating panel too, no difference.
(In preferences, of course, I set the needed option. I never changed it. I think, the bug started with 2.88b.)
(And, in last some hours Mp3tag crashed about 5 times, with 3,000 files and with 26,000 files too, in different situations. In error log: allways some "sflac..." thing -- but I forgot it... When (if) repeats, I write it here.)
(And, in last some days. I have a long, about 3 times as app's window, tags' panel on the left side, vertically. I want to change something down, for example the cover. Click in it -- and the panel pops to the most up. And vica versa, too. Not all time, but frequently.)
