Cant tell you how many times I have filled everything out only to click away to get more info and lose all of what I just typed when I click back on the mp3. Would be nice if it persisted or if at least it got stored in the drop downs. Thanks as always! v2.49
Learn not to do that.
I only occasionally forget to save. More often what I do is mistakenly select only one file when I intended to select all of them, fill out the Tag Panel, then save. Luckily, this data is then available in the drop downs.
Have you tried "File > Options > Tags"
[x] Save tags when using arrow-keys/single mouse click ?
