Hello,
if I have for example 10 different MP3s with different covers and I save, the files get the same cover.
In MP3Tag everything looks normal, each file has its own cover.
But if I play the files with e.g. VLC or AIMP, only the cover from the first file is displayed.
I can make a video or upload some example files.
Do the files have the same cover in Mp3tag after saving or are they still showing the different covers?
I think i found the problem.
You can't have different covers for one CD. So, in my case, i changed the CD-Number equal to the track number and now every track / title has it's own Cover and shows properly.
Maybe thats how i can make a compilation.
This depends on the player, and is not a function of mp3tag.
system
Closed
November 21, 2021, 6:47pm
5
