Saving Shortcut / Create playlist shortcut conflict
Hi there. After updating to v3.35 on Windows 11, the shortcut "Ctrl + S" has an issue. Instead of just saving the tag, it also tries to create a playlist. Is this a configuration setting, or am I missing something?
Could you update even further to the latest beta and see if the behaviour persists?
Or: I am using 3.35 beta.1 and mine does not try to create a playlist with Ctrl-S
Thanks, the update solved the problem.
