SayNextWord in web sources broken?
Here is an debug excerpt which shows - in my opinion - that SayNextWord is broken. The log shows that SayNextWord only outputs the first character not the complete word. I expected mp3tag to output the text 'clearcut' in that particular case.
Thanks for reading
Script-Line    : 243
Command        : findinline
Parameter 1    : ><td><
Parameter 2    : >1<
Parameter 3    : >1<
Output         : ><
Line and position:
<td>clearcut 2006    50 Min. - Originalhörspiel dt. </td></tr>
Script-Line    : 244
Command        : saynextword
Output         : >c<
Line and position:
seems like there is a problem
as a workaround, you can use:
sayuntil " "
if it is always a space which follows the word.
It seems that SayNextWord needs the boundary of a previous word to detect where the next word start, something of \b in a regexp.
DD.20110405.1215.CEST
If so, try
findinline "<td"
instead of
findinline ""
before the saynextword command. then the parser shoul be able to read > as the word boundary before the word.
