Folks:
I'm wondering if there is a scripting equivalent of CTRL-S? In other words, is it possible to add something to a script that would immediately write all of the tags in the tag panel to the selected files, before executing the next line of the script?
Here's what I'm getting at:
I usually tag entire folders to populate the ALBUM field with the contents of DATE and VENUE and some other fields. I enter the date and venue by hand, and then I have a script to populate ALBUM. That script works fine. Like all(?) "Format" scripts, when it runs it flushes the altered tag to disc, the files, no problem.
The problem is: before running the script, I need to manually save the contents of the tag panel to disc. If I just run my ALBUM script, the script thinks that DATE and VENUE are blank. I guess it reads from the file, not from the tag panel. So I need to use mouse or keyboard to save everything first.
Being both lazy and geeky, what I want to do is add a line to the script that says "write the tag panel to disc," just like clicking the save icon would do. So, like this:
{{{{CTRL-S}}}}
Format value "ALBUM" : $if($and(%year%,%venue%,%source%),%year% - %venue% - %source%,%year% - %venue%)
Etc.
Is there a scripting equivalent of "CTRL-S" that will pick up whatever is in the tag panel and flush it to disc?
Maybe there's a better way to do this? I suppose I could start the script with something like:
Format value "DATE" : %date%
. . . . and so forth for each of the tags I want saved. But that's not very flexible.
Sorry if I've missed the obvious . . . . Thanks.
