That you get an empty file can also mean that you do not have duplicate albums.
The structure of the files does not really matter as the script compares then name of one ALBUMARTIST and ALBUM with the next record but only gives an output if the ALBUM has the same data but the ALBUMARTIST is different. "Greatest Hits" albums are good test cases for such a constellation.
I tested it on a set with
Earth, Wind & Fire - September
Earth & Fire - September
an other tracks and it produced at least one of the "September" albums.
You may now twiddle around with the script: the comparison statement is there, you only have to adapt it to your data.
I think it may be due to the "ALBUMARTIST" label. I'm not sure if I have labeled, although I'm sure to have album of the same name. I'll check when I return trip on monday.
Until monday I can not check it. Thanks!
Hello! I have correctly labeled " ALBUMARTIST " label ( from the beginning of the post) , but I think I did not explain well . What I want is to find the same album names of different artists . For example:
This is exactly what my script found in my collection...
To be honest: any kind of differences in spelling or in the cases will result in the interpretation that an album is a different one... so the script is not very clever.
I would suggest that you sort the albums alphabetically and scan them naturally with your eyes.
But why it works for you and not for me?
Are you sure the script is well copied?
I have different artists with album titles exactly alike
It should find some match and yet generates me a blank file with line breaks.
Have you tried to work with completely different artists?
A visual search many albums would be very tedious
The linebreak after the comma is intentionally there.
It has now worked, but not quite. He has omitted some matches, I do not understand why. This is the result of a very short list for the tests I'm doing are not too long (only with albums that have the word "collection")
(Here has left a blank)double: John Mayall: The Collection
double: Dizzy Gillespie: The Gold Collection CD1
double: Django Reinhardt: The Gold Collection CD1
double: Wynton Marsalis: The Gold Collection CD1
double: Dizzy Gillespie: The Gold Collection CD2
double: Django Reinhardt: The Gold Collection CD2
double: Wynton Marsalis: The Gold Collection CD2
He has not found the following:
Bobby McFerrin: The Collection
Chick Corea: The Gold Collection CD1
Chick Corea: The Gold Collection CD2
Again: it is no script for the most elegant output. It has its limitations.
You are now free to adapt it to your data and needs.
And quite honest: you would have to look for each of the hits anyway to rename the albums.
During this process, you will find the "CD2" ones.
Also, I do not see it as an elegant way to put the CD number into the album name as it is still the same album. DISCNUMBER would be the best field to store the CD number.
I also use the tag "DISCNUMBER" but I'm interested in separate the CD1 of the CD2 because sometimes i want to hear the CD1 but do not want to continue with the CD2 at that time or the other way around. As if they were real disks that came two separate CDs. That way I have ordered my Ipod Classic.
