tldr: is there a function or another way of accomplishing this:
$if(X,SKIP-THIS-FILE-DURING-BULK-EDIT,Y)
My use-case is for files that lack complete metadata, but already have a valid filename; I would not like to touch these.
$if($eql(%albumartist%,),$if($eql(%artist%,),%album%-,%artist%-),%albumartist%-)
Above is how I initially started to try and solve this problem, a string of if statements to cycle through albumartist then artist then album if the previous were blank, but if all of these are blank I will ultimately run into the same issue. I’d like to surround this entire statement in another statement that says, “if blank, then just don’t edit the file cuz id like to go back over this manually.”
Edit: I suppose technically a (bad?) workaround is to create a custom metadata field where I could store the original filename before making any edits.
