I think this is possible, but my scripting abilities are a bit weak.
My library is organized so that the top level folder is "artistname _XXX", where XXX is a 2 OR 3 digit number always preceded by the underscore. This number represents my own genre code and is always at the end of that top level folder.
What I'm trying to do is write a script that would determine that genre code and then apply it to the genre tag for all MP3's within that folder (including any subfolders).
within are 2 folders:
'89 +Sewa Kan]Wassalon
'95 Mogobalu
within those are the MP3's + JPG covers/info.txt
additionally, anther folder at the same level as M Keita, is:
Kankick]...from Artz Unknown _51
within that are the MP3's + JPG covers/info.txt
I would like to script something that scans for the "_" and takes the following number "113" or "51"
and applies that to the genre tag for the MP3s contained within. So for Keita, it would tag both albums, for Kankick it would tag the files within.
Those codes are always at the END of the folder names. Notice that the subfolders for Keita, do not contain the code - only the top level folder.
